Цифровая камера Panasonic, выпущенная в сентябре 2013 года. Камера оснащена 60-кратным оптическим зумом, а также функцией записи HD-видео и звука.
Flash does not light up
I have a FZ72 (which is very similar to FZ70).
The flash does not work. If I open it, the camera recognises it and also preloads the flash. But if I press the button to take a photo, the picture is taken and no flash lights up.
I assume the cables could be broken, because for some time the flash only worked, if I pulled the case of it a bit backwards.
My question is, what is the tiny blue device behind the flashlight. Also there are 4 cables altogether. Which could be broken? Is it possible to fix it at all?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @hilfs08,
Check the capacitor and the connections to the capacitor are OK. This component provides the power for the flash to operate.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Unfortunately this did not help. The cables to the flash are covered on the flash-side by rubber, so you cannot measure anything. However I tried to discharge the capacitor and it recharged after turning on, but still no flash. :/
I assume the cable is broken somewhere, but since it is tightly attached to the light itself, I would have to find a new set somewhere...
из Поделиться
Добавьте свой ответ
Phil буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 26
За все время: 796
