Контроллеры для шлема виртуальной реальности Valve Index, выпущенные 28 июня 2019 года.
Battery Replacement for Index Controllers
In February we were promised guides and parts for the valve but this place is empty and void of any valve teardowns or parts. What happened? Was the plan scraped? Lots of users need new batteries for the controllers, some of those devices are 3 years old now.
It’s still the 2nd most popular vr headset on the market.
Это хороший вопрос?
Счет 19
Добавить комментарий
5 Ответов
Наиболее полезный ответ
Two things. First, many of the guides at iFixit are user generated. A Quality Guide takes time to complete. Even if you know the process by heart, it still means documenting the process step by step. This entails photographing and/or videoing the process. Writing everything out in clear and concise steps and assembling everything together in a way that tells the story of how to perform the repair.
Second. I cannot speak for iFixit, but I don't know that there was mention of documentation being specifically provided as part of the agreement with Valve, only providing parts. I suspect guides will come (user generated or otherwise), but iFixit sells lots of parts that do not have explicit guides for install. And agreements for distribution/sales of that sort also take time to hash out and implement. Apple announced their Self Repair program in November and just rolled it out a few days ago. I know it's not always the easiest thing, but I think in this case, patience is the best antidote.
Был ли этот ответ полезен?
Счет 5
1 Комментарий:
In order to diagnose a charging issue on my controller, I drafted a guide of my procedure: Замена аккумулятора правого контроллера Valve Index . I welcome anyone else who can to review and append any details or pictures that I may have missed. I feel a guide on this site is significantly better than relying on scattered YouTube videos or Reddit posts.
из Поделиться
Now a replacement battery can be obtained at XINJ store on Aliexpress. It's a 1000mah battery, not 1100mah as the original one, but it would work as a replacement in case Valve refuses to help.
Video with controller disassembly up until the battery compartment can be seen here:
https://www.youtube.com/watch?v=2p8VTLdd...
How to replace the battery with a connector (I'd still go for solderinng tbh):
https://www.youtube.com/watch?v=ODQ-un51...
______________________
OLD:
Info about battery can be found here.
https://www.reddit.com/r/ValveIndex/comm...
PL802056V 3.8V (model number)
1100mah 4.18Wh (specs)
+18100604-1 (this looks to be battery serial number, as I found 2 different ones)
More details in my own disassembly:
10.78x56.86x21.47 in paper fold with rubber pad and expanded chamber and control board (finished battery).
50.59x19.24x9.62 just the normal dimensions without control board and expanded gas chamber (just the cell without wires/board).
Model number under paper is the same: PL802056V 3.8V 1100mAh 4.18Wh
Serial number is different from the paper wrap: 19072902-1
Счет 5
The image of the guide containing the information:
Not sure if that helps but usually the model of the battery shows the dimensions, so 802056 would be 8mm x 20mm x 56mm. It would be great if someone confirms the dimensions. Also, LP could be for lithium polymer.
Two notes from the guide:
  • the og battery is 3.8v nominal and the controllers charge it to over 4.3v, if you use the controllers to charge an external cell do not use a regular 3.7/4.2v one or it will explode.
  • The white wire from the original battery seems to be for a thermistor as it measures ~10kOhms to ground
With all these information I still can't found a replacement battery to buy :-/
Счет 3
1 Комментарий:
https://www.reddit.com/r/ValveIndex/comm... I disassembled a controller just yesterday.
10x20x51 is just the battery module without control board
из Поделиться
Given the complexity of the repair and the risk of significant breakage, wouldn't it be simpler to provide an external battery solution connected via USB type C to the controller with a battery holder. It would be enough to have wristbands with a pocket, it's not expensive, 10€ maximum
https://www.amazon.com/Pockets-Running-W...
https://www.amazon.com/Type-C-Cable-10in...
https://www.amazon.fr/Cameron-Batterie-r...
Счет 0
7 Комментариев:
but in the case of an external battery which battery to choose and how to recharge it because for lipo batteries you need a charging socket and a balancing socket?
из Поделиться
Can't we directly connect a 5V 3A 5000mah battery to the controller by USB C cable?
https://www.amazon.fr/Cooopoo-Batterie-R...
из Поделиться
It’s an option but this is heavy and painful in some games like beat saber. I personally got issues again with my controller battery (will try a second replacement) and use a powerbank in my pocket with long wires in the meantime (you could path the wire in your shirt/strap it
из Поделиться
rather than a long cable that runs around the body I think the pocket wrist option is preferable
[image|3426321]
из Поделиться
Would it also be possible to use a 27000mAh 22.5W External Battery Portable Charger / tablet? to have greater autonomy or a fast charge of the controllers during the game.
из Поделиться
Показать ещё 2 комментариев
As of recent, there has been a guide authored by the community to replace the batteries in the Valve Index Controllers.
Created by Damian, here is the guide in question: Замена аккумулятора правого контроллера Valve Index
I followed this guide myself, as it came out shortly before I was going to create my own iFixit guide after I ordered replacement batteries, but this guide came out first, and it is well written.
I have added a few comments to certain steps of the guide to hopefully add an alternate method as to removing the batteries when the controller is opened.
I hope this helps, the repair was not as bad as people initially thought, but it should still be carried out with great care, I used tools found in my iFixit Pro Tech Toolkit, some 91% IPA, a plastic pipette, and a long and thin Torx T5 screwdriver, like pictured in the guide, as needed for one of the 5 screws that need to be taken out.
I will add, the iFixit precision bit screwdriver just BARELY reaches it when I did it, with the T5 bit hanging 3/4 of the way out of the end of the screwdriver, but I would not recommend it, it is at high risk of having the screw head getting stripped, don't take the risk I did, get a dedicated small set of small Torx bit screwdrivers.
Счет 0
Добавьте свой ответ
Ryan Richardson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 27
За последние 30 дней: 181
За все время: 24,056
