Lenovo ThinkPad L460 — это 14-дюймовый бизнес-ноутбук, выпущенный в январе 2016 года. Он отличается прочной конструкцией, матовым черным дизайном и красным джойстиком TrackPoint в центре клавиатуры. Вес устройства составляет примерно 1,9 кг. Ноутбук оснащен процессором Intel Core 6-го поколения и функциями обеспечения надежности. Он отлично подходит как для бизнеса, так и для учебы.
Problem with screen or motherboad?
My lenovo T460 has no 3.3V and no other voltages on screen controller board (CON) except the 20V on the connector and in a big coil. Also no backlight and no picture. Is it possible to have fry anything in main motherboad ? (My hdmi output working normally with my external monitor).
Initially I changed the screen cable, because my screen was changing colors and making vertical shades with freezing picture, especially when the lid was moving.
Initially the problem seems to had be solved ,but after 5 min the problems return, so I opened the screen and begun probing on the CON for voltages and any defect cups and at that time the backlight and the picture was on, with the defects showing..
Now it's only a black screen.(with working hdmi output to TV)
The question is how do I know that I haven't done anything wrong with the motherboard, while I was probing the screen con board ? The 3.3V and other voltages are coming from the motherboard though the screen cable or from the lcd controller board?
Where could I have to start searching ?
I Appreciate your time
Это хороший вопрос?
Счет 2
1 Комментарий
Mine has no display but shows charging light and power light
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
Hi @metachaos
Couldn't find a schematic for a T460 but found one for a T460s (Compal NM-A581 motherboard) which shows that the backlight power is supplied via fuse F6 on the motherboard and goes to pins 27 & 28 on the LCD connector.
If the fuse is blown it is a 3A_32V_ERBRD3R00X.
If there is no power on either side of the fuse, the power comes from Q1 (TPCF8002_2-3U1A)
If there is power on the pins then then backlight is turned on and off in the screen by a backlight enable signal sent on pin 18.
Here's the schematics that may help you further, (scroll down to the download link). Go to p.38 to see the pinout for the LCD cable connector.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Lord Chaos буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 31
За все время: 1,151
