Информация по ремонту Creality Ender 3 Pro — улучшенной версии 3D-принтера Ender 3 производства Creality. Выпущен в сентябре 2018 года. Номер модели: Ender 3 Pro.
3D printer blue screen
Built printer, then it turned on. Leveled the plate to the print Nozzle with a piece of paper. I printed 2 test models then a 5 hour model. All 3 models we fine. Then turned off printer. The next day I turned the printer on and only got a Blue screen.
Это хороший вопрос?
Счет 4
10 Комментариев:
was the printer bumped at all?
из Поделиться
No.
I did a puzzle tube print which took 5 hrs, when it was done I turned the printer off. The next day when it turned it on it had the blue screen.
из Поделиться
ok, check the connections maybe. there is one on the back of the LCD and another inside the CPU
из Поделиться
Are you using octoprint or an SD card to print your models? Try using octoprint instead on an SD card, I accidently inserted the wrong SD card and it corrupted the firmware. Try re-flashing the firmware , that usually did the trick the few times it happened to me. On one occasion the LCD connector was loose. good luck.
из Поделиться
I checked all the connections before hand and then went through a lot of different things that others have said to do., nothing helped.
I just don't know what else it could be. It is brand NEW. I just got it and did 1 print job, turned it off after it was finished, next morning turn it on and got the blue screen.
из Поделиться
Показать ещё 5 комментариев
Добавить комментарий
1 ответ
its 1 of 3 things u have a loose LCD or not connected properly it could be that u have attempted to mess with the power management by accident and now it's has too much/&or to little voltage and is ether broken or not working properly, or 3 it's something on the board that's needs replacing these are the most common things i run into
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Frank Lovash буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 11
За последние 30 дней: 29
За все время: 4,259
