Xiaomi Redmi Note 9 — это смартфон среднего класса от компании Xiaomi, выпущенный в апреле 2020 года. Он оснащен 6,53-дюймовым IPS LCD-дисплеем, основной камерой на 48 Мп, расположенным на задней панели сканером отпечатков пальцев, аккумулятором емкостью 5020 мАч и работает на базе процессора MediaTek Helio G85.
Device reboot continously when in Standby-mode
Good Morning,
i have the phone of my mother in law and it's rebooting continously when in standby. as long as the display is on, you can use the phone normal, but after locking it device starts to reboot again and again. did someone have this before?
btw: Chargng is a little bit slow, but i think it's because of the reboots (more power needed).
Это хороший вопрос?
Счет 1
3 Комментариев
Have you tried to update software or firmware? It could maybe be a Internal Issue but im not sure what would cause it.
из
this is impossible, because when i tried it it fall back to bootloop at 64% Updated.
из
non of the above works i have tried power and volume+ button but it is not going on that
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
@m0ddmylife
What happens if you start the phone in safe mode?
If still no good, here's a link to the schematics which may help as it has Level 1, 2 & 3 repair instructions.
I haven't tried this link but have used the website before for other makes and models and they were OK.
Был ли этот ответ полезен?
Счет 1
Your smartphone might experience a reboot loop if its cache memory is full. To test for that possibility, you should empty your phone's cache
Regards,
Will
Счет 0
1 Комментарий:
I've set it back to Factory mode multiple times, so this is not working.
из
i have a had the issue a couple times what i do to fix this is, is to hold the power button until the lock screen appears
Счет 0
Добавьте свой ответ
Michael Kastner буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 14
За последние 30 дней: 34
За всё время: 1,456
