Информация о ремонте и разборке смартфона Pixel 6 от Google, выпущенного в октябре 2021 года. Идентифицируется по номерам модели GB7N6 и G9S9B16.
Pixel 6 touch screen less precise after replacement
I have had my Pixel 6 screen replaced after a big crack.
After finally fixing the fingerprint sensor issue, I still find myself with a major problem:
The touch screen is less "precise" when typing fast. Namely, when I am writing fast and touch the screen in two points almost simultaneously, it interprets it as a "swipe", and therefore misses the first of the two touches.
This had never happened before the change. Is this a known issue, or could it be a problem with the new screen itself?
Thanks!
Это хороший вопрос?
Счет 2
Добавить комментарий
3 Ответов
Наиболее полезный ответ
This is likely a defective screen. See if you can get a refund or replacement. If it was a cheap screen, it may just be very low quality.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Thanks, that was also what I thought. It was however not a cheap one, and was (according to the seller) an original piece. Will ask for a refund
из
I have this same issue and also when I call someone the screen flickers
Счет 0
Hi. I don't have an answer, but I also got my screen (only the touch part) replaced by a third party (Pixel 6 wasn't launched in India) and have the exact same issue. How did you fix it?
Счет 0
Добавьте свой ответ
Davide Di Nello буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 10
За всё время: 1,154
