Модель: PowerShot SX700 HS (PC2091/PC2093/2047) Номер корпуса: 902053007176 Дата выпуска: апрель 2014 г.
Pop up flash problems
I have two Canon SX 700 HS cameras. Each with a different flash problem.
On the first, the flash works, but the internal catch to hold it down is either broken or disconnected so it won't stay down.
On the second, the flash physically works in place, but the settings and flash don't function or flash.
I'd like to fix both, but if need be, use one to fix the other. Is there anywhere I can find schematic drawings of this camera so I can get into it without blind luck?
Any suggestions would be appreciated.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @drkenrich
For the broken catch problem here's a link to the parts catalogue if you're willing to buy it.
Can't find the schematic and the supplier linked above doesn't show it but perhaps you can ask them if they have it.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Ken Rich буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 37
За все время: 477
