Представленный 13 октября 2020 года, iPhone 12 mini является уменьшенной версией Apple iPhone 12. Он оснащен 5,4-дюймовым OLED-дисплеем, процессором A14 Bionic и двойной основной камерой.
iPhone 12 mini black screen
i have an iphone 12 mini the screen is black. However when i place it on a wireless charger it gives a charging beep but the screen remain black. What could be the problem? is it the screen or the battery not charging??
Это хороший вопрос?
Счет 1
4 Комментариев
It probably died and you have to get a new one.
из Поделиться
thank you. U mean new battery not new phone?
из Поделиться
New batterys
из Поделиться
And if that doesn't work you might have to buy a new phone.
из Поделиться
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@sirneilsirneil try seeing if it will connect to itunes, it could possibly be in dfu mode
Был ли этот ответ полезен?
Счет 1
I'm going to disagree with @liljk; there's nothing to indicate a bad battery at this point. The fact that you get a normal reaction when setting it on a wireless charger says that the phone is running. I'd want to do some investigation first, but in situations like you're describing it's generally a screen problem.
First thing to do is try plugging it into a computer and see if it's recognized. If possible, try doing a full restore of the phone's firmware to try and rule out the possibility that it's a software issue rather than hardware.
Worst case in my opinion is you have to replace the screen. Here's the iFixit guide do to that.
Замена экрана iPhone 12 mini
Счет 1
Добавьте свой ответ
Sir Neil (Sirneil) буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 28
За все время: 690
