Четвертое поколение умных часов Apple с опциональным сотовым модулем, выпущенное 21 сентября 2018 года.
Taptic engige or antenna replacement?
Hello. while replacing a battery for Apple watch serie 4 40 mm i damaged a part that sits on the taptic engine.
Looks like is not part of the Taptic Engine though, because is not connected.
It looks more like an antenna board to me. Could you please help me identify the part, and in case help me to find a seller or that?
I searched everywhere and i can't fiund it for sale.
If I look for taptic engine, that part doesn't come with.
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
There is a coax connection on the Taptic unit. The cable incomes around from the case side which you can see in the video in the Замена Taptic Engine в Apple Watch Series 4 guide. So you will need to replace the part and if you damaged the cable end that too.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Yes i saw and followed that video and the coax socket is what i broke.
So.. any idea what's the name of the little part and or where i can find it for sale in Europe?
из
@jacopocanova - it’s part of the Taptic Engine part. Sorry I don’t know where in the EU to find it.
из
@jacopocanova you can get those connectors from Mouser.com in Europe as well, This link is for the US site but the same mouser part numbers apply for the european stores. Parts are inexpensive but Mouser is expensive shipping so you may want to shop around any of the major electronic parts store. I believe Farnell in the UK carries those as well.
Счет 0
The Apple Watch Series 4 is nearing iPhone levels of reparability, with the highly-glued display being the primary remaining obstacle. Beyond that, they say the battery is straightforward to replace. Thanks.
Счет -1
Добавьте свой ответ
Jacopo Canova буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 28
За всё время: 916
