OnePlus 8 Pro — это смартфон на базе Android от компании OnePlus, выпущенный в мае 2020 года. Эта страница посвящена региональной модели IN2023 и сборке Android с названием OnePlus8Pro.
Fingerprint Sensor Not Working After Screen Replacement
So yesterday I had my screen replaced (was grenaded after it met my bed frame edge) and it all went perfectly fine. The only thing that bothers me now is the fingerprint reader. I can register new fingerprints without a hitch like normal, so I know it's working fine, but after setup my fingerprint just doesn't work, like something is suddenly making it not read. Has anyone else ran into this?
Это хороший вопрос?
Счет 4
Добавить комментарий
7 Ответов
Наиболее полезный ответ
If you transferred the original finger print sensor from the old display to the new one, it typically requires recalibration. If not, then the finerprint sensor is programmed to that specific device and a new or replacement one won't work without reprogramming it. As far as I know, oneplus doesn't make the reprogramming software publicly available. Thanks, OnePlus!
This one on eBay should do the trick https://www.ebay.com/itm/275420607111?ch...
This guide should help as well https://www.youtube.com/watch?v=FsZFyGXc...
Был ли этот ответ полезен?
Счет 2
4 Комментариев:
Oh wow, that's odd. I would've thought that with the sensor being in-built that it would just be plug and play like the display and literally every other capacitive thing with it. I haven't tried the usual troubleshooting like rebooting and such (and I'm not factory resetting this phone unless I'm selling it). Guess I'll see where the links you provided get me. Is that same tool available on Amazon by chance?
из
If you can register new prints have you removed any old prints then tried again?
из
@razorx you'd think it would work like that but no. I haven't seen it on amazon but it's worth a shot to check
из
How can you reprogram the fingerprint sensor?
из
OnePlus said that no calibration is necessary after installing a replacement screen and digitizer on the OnePlus 8 Pro. Current as of 06/10/2023.
Счет 0
4 Комментариев:
@schleems18 it must be necessary surely. Otherwise how does my fingerprint register fine but never works in practice?
из
I haven't attempted changing or adding a new fingerprint, everything functioned as it had before the screen replacement. Have you tried a factory reset? You could also try adding the same finger a couple times, just in case.
из
@schleems18 I'd much prefer not factory resetting, I don't want to go through the faff of recovering everything. And I did try adding a couple times, no avail. As of late I've just been living without it
из
I'm facing the same issue
из
phone display not on
Счет 0
1 Комментарий:
how to on phone dispaly
из
Fingerprint issue
Счет 0
1 Комментарий:
Fingerprint scanner issue
из
Will it work after a hard reset??
Счет 0
I have faced that problem after display Replacement in oneplus 8 pro. Any solution here plz?
Счет 0
fingerprint not working
Счет 0
Добавьте свой ответ
Razor X буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 11
За последние 30 дней: 58
За все время: 10,152
