Ремонт и дополнительная информация о холодильнике GE GFE26JGM**** — модели с автоматической системой размораживания, без ледогенератора и диспенсера в дверце, впервые поступившей в продажу в 2019 году. На этой странице представлена информация для номеров моделей, соответствующих шаблону GFE26JGM****.
Wiring connector assembly help
Removed the doors, while disconnecting the harness, the connector came off. The color of the wires don't match. We need help matching the wires back up
Black/yellow, white, 2 white/blue
Black yellow, white, red/white, gray/white
Update (05/05/23)
Update (05/05/23)
  • trying again
Update (05/05/23)
GFE26JGMWFBB is the model
Это хороший вопрос?
Счет 1
3 Комментариев
can you add photos
из Поделиться
@dougwilds i can't see them doug it just says image
из Поделиться
@dougwilds pictures can only be added to Question or Answers , not comments. It's fixed :-)
What make and model is this?
из Поделиться
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @dougwilds
I can't find the mini manual (GE part #31-1000533) for a GFE26JGMWFBB but there are two models which are very close, i.e. GFE26JGMAFBB & GFE26JGMNFBB.
Unfortunately they have different mini manual part numbers not only from your model but from each other as well. Maybe there are slight variations in the wiring due to them having different features perhaps
At least they show the connections and colours of all of the wires used
GFE26JGMAFBB (31-1000396)
GFE26JGMNFBB (31-1000474)
Using an Ohmmeter, you may have to identify the wires by colour back to the main board connector pins, by looking at either of the manuals to see if one is appropropriate.
Hopefully one will be and then once you know where they connect to on the mainboard, use that manual to see where they go to and what colour wire they connect to or end up as.
Hopefully this is of some help.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Doug Wilds буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 8
За последние 30 дней: 28
За все время: 640
