iMac will not fully boot
I have either the original or 2003 model of iMac G4. The base plate says 800MHz/60/256 and it uses the older airport card.
I got this in a lot of other Macs and don’t know the background. I cannot get the machine to boot. I have replaced the PRAM battery as well as pressing the reset button that is next to the airport card.
When plugged in and I press the power button, the fan will kick on for a second and shut back off. There is also a red light that appears under the iMac near the airport card for the same duration of a second and shut off.
Not sure what else to check. I’ve removed both RAM cards as well as trying each individually with the same result of only coming on for a second.
There are no other lights and no tones indicating bad RAM or other post issues
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
I would inspect the power supplies electrolytic capacitors as this system suffered the capacitor plague
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Dang. Alright I’ll tear it apart a little more and look at them. Thanks
из Поделиться
Добавьте свой ответ
Michael буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 22
За все время: 438
