Ноутбук от Samsung, выпущенный в 2016 году, идентификационный номер модели: NP740U5M - X01US
cover (lid) part specifications
So i recently purchased this model used, and ilove it. one issue is that the previous owner replaced the battery at some point and when they did they stripped a couple of screws that hold down the lower case (lid) to the laptop. im struggling finding out what the screw specifications are to find a replacement screw and .......grommit? nut? whatever it plugs into. do you possibly know where i can find this info or replacement?
Update (10/02/23)
Это хороший вопрос?
Счет 1
2 Комментариев
@karatemast40262 you are referring to a NP740U5M - X01US right? Can you post some pictures of what you are looking at? That way we can see what you see and hopefully find what you need. Добавление изображений к существующему вопросу
из
[image|3091394][image|3091395]
The case isnt damaged at all, but i wanna get this fixed so the case doesnt keep popping out like that. I've already pulled the entire case off and it went back together fine.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @karatemast40262
If you don't get a better answer and maybe it's a bit expensive for just a couple of screws, but here's a supplier of a screw kit for the model. The required screws should be in the kit.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
karatemaster161988@yahoo.com буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 22
За все время: 339
