Samsung Galaxy M51 — это смартфон на Android, выпущенный в августе 2020 года.
Charging problem fast charge not working
Charging problem charging is slow fast charging not working
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Hi @vijayrobin
Use a strong light and a magnifying glass to visually inspect the charge port connector to make sure that there are no bent or missing pins and that there's no debris lodged in the port e.g. lint, that may be preventing a good electrical connection with the charge cord plug. If there is any lint etc, use a vacuum cleaner to try and clear it.
If the port appears to be OK then here are some images showing the charging troubleshooting flowchart and also zoomed in and normal sized images showing the components mentioned in the flowchart on the systemboards.
If you determine that the charge port is faulty here's a video that shows how to replace the charge port board (known as sub pba in the flowchart)
Search online for GH96-13765A to find suppliers of the charge port board that suit you best.
(click on image)
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
my samsung galaxy m51 is not responding to any kind of charge . I have tested it with realme, xiaomi, motorola and samsung charger and it is showing no sines of charging
из Поделиться
@devrajbasera
Follow the troubleshooting flowchart as shown above.
из Поделиться
Добавьте свой ответ
Vijay Robin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 25
За все время: 493
