Дата выпуска: январь 2019 г. > Характеристики: 14-дюймовый дисплей - Core i7-8565U - NVIDIA GeForce MX150 - 16 ГБ ОЗУ - 512 ГБ SSD Официальная страница - https://www.asus.com/Laptops/ASUS-ZenBook-14-UX431FN/ Newegg - https://www.newegg.com/utopia-blue-metal-asus-zenbook-ux431fn-ih74-mainstream/p/1TS-001A-00S86
How to fix my audio jack?
I accidentally pulled out my earphone at an angle and when I tried to put them back in the audio jack, it won't play any music. I think it should be the audio jack as the other earphones also don't work on it while when I plugged my earphones to another device, they work.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @camille8001
It seems as though the headphone jack itself may have been damaged.
If this is the case then it cannot be repaired, it has to be replaced.
The easiest option is to replace the IO USB board (supplier example only) as the headphone jack is mounted on the board.
I couldn't find a video that shows how to replace the board but here's a video that shows how to open the laptop so that access to the board is possible.
The board is visible at 1:31 minutes into the video.
Note: To avoid any possible electrical problems from occurring when working inside the laptop, disconnect the battery cable from the motherboard as soon as you can access it before doing anything else. This is shown at 1:34 minutes into the video. You don't have to remove the battery, just disconnect it. Reconnect it last thing after completing the repair, before closing the laptop
If doing this yourself is too daunting, contact a reputable, professional laptop repair service and ask for a quote.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Camille буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 23
За всё время: 284
