Not able to boot from ssd .
I have added an ssd to the laptop have windows 10 and the harddisk is containing the previous os.
But when turned on the default boot option is harddrive rather than ssd.
When tried to change it unable to change .
Every time i need to press f9 and select the drive to boot from.
Hp 15s-du3053tu
Update (10/27/23)
Это хороший вопрос?
Счет 0
2 Комментариев
[image|3113785][image|3113786]
This is images of the screens during the operation
из
@jayeff
I think one of the drive is not showing as bootable device.
What can be done for that.
из
Добавить комментарий
1 ответ
Выбранное решение
Hi @basil33672
Try the following and check it it resolves the problem.
Press Win key + r key (both together) and type msconfig in the box.
In the Boot tab:
Select the OS (drive) that you use on the next boot and select Set as Default.
Set the Time Out to 0 seconds
Click Apply and restart the PC.
If you want to use the other drive then follow the same procedure again and select the other drive as default
Был ли этот ответ полезен?
Счет 1
6 Комментариев:
Okay i have checked in that way but still it is going for automatic repair and stuck in the same situation
из
@basil33672
Getting a bit confused.
You said that Win 10 was on the SSD and the "previous OS" was on the HDD yet in the image you posted shows the Win10 OS is on the "C:" drive.
Was the "previous OS" Win 10 also i.e. do you wish to have 2 x Win 10 systems?
How did you install Win 10 on the 2nd drive?
из
Hey,
Actually the issue is we are unable to select from the boot option os manager where they have mentioned press F5 F6 to move up and down then hitting enter key does not work to make the primary boot device as ssd.
You can seen from the image.
Do you suggest any other keys to make the selection.
Which may the solve the problem.
Since during booting its trying to boot from the hard disk where the windows os in the hard disk has been crashed. Thereby always it going for automatic repair.
из
@basil33672
What OS is on the hard disc that crashes?
Was the SSD Win 10 install an new install or was it an existing drive from another PC?
из
Hey,@jayeff
i am able to set ssd as primary boot .
But another issue observed.
When the system undergoes sleep and when wakes , it goes for automatic repair where the primary boot option is changing back to hard disk.🤯
I don't understand what is happening.
Please help me if you have any idea.
Windows 10 home on hard disk.
из
Показать ещё 1 комментарий
Добавьте свой ответ
Basil буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 13
За всё время: 483
