Информация о ремонте и разборке смартфона Pixel 6 от Google, выпущенного в октябре 2021 года. Идентифицируется по номерам модели GB7N6 и G9S9B16.
Display does not respond to touch
Phone was dropped, then the touchscreen became intermittently non-responsive. Applying pressure to the sides of the device or providing some flex would get touch functionality to restore for a while. Eventually even this stopped working and the touch functionality stopped working entirely although the display itself is still perfect.
I figured this must be a screen issue though I dont understand why only touch would fail and not display; so I ordered a replacement screen and hooked it up to test but again have the same issue, display works perfect with no touch input being accepted. I inspected the connector/board for the display and don't see anything wrong (although I dont have magnification). I cleaned the board side of the connector with 90% IPA though it made no difference.
Anyone have an idea of what to look for? I understand I will most likely need a new phone at this point but I'm still interested in what went wrong.
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Have you rebooted the phone with the new screen attached? I had one one that needed it to be done twice before the screen was accepted and the touch then worked. You may even have to reset it if just a reboot doesn't work.
Был ли этот ответ полезен?
Счет 0
3 Комментариев:
Did old screen work? I have the same issue touch is not working even though there is no crack
из
hi i have the same issue there was no cracks whatsoever is there anything u can do about it? or how did u fix it?
из
My Pixel 6 Pro took 5 reboots before it finally recognized the touchscreen and started to work. I still had to run the google tool to enable the fingerprint detector, but that was rather trivial.
из
Добавьте свой ответ
Mike Meller буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 16
За последние 30 дней: 48
За все время: 2,380
