Sony Ericsson W580i — это слайдер в стиле Walkman с 2-мегапиксельной камерой.
Lines on the display
Hello everyone. I have a Sony Ericsson W580Ii with a screen issue. It dropped on the ground (not on display side, but dropped on the back) and after that accident, I see lines on the bottom sides of the display. Can it be an internal flexible cable connecting the two halves of the phone, flexible cable connecting the display to the motherboard or the LCD the problem?
P.S.: I'll insert a photos to describe the problem.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Hi @stanislavaz2584
I think it looks more like a problem with the LCD display. Even if it did land on the back of the phone when it fell, the shock when it hit the ground could have been enough to cause internal damage to the display
Here's the ifixit Замена ЖК-экрана Sony Ericsson W580i guide that will help.
At least you can check the cable connections etc to make sure it is OK.
If you think that it is the display then search online for Sony Ericsson W580i Display (LCD) to find suppliers that suit you best.
Here's the service manual as well that may also help.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Stanislava Zubkova буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 17
За всё время: 290
