Ноутбук Lenovo IdeaPad 110-15ISK был разработан компанией Lenovo в США в 2015 году. Модель Lenovo IdeaPad 110-15ISK можно определить по номеру модели: 80UD.
Second Graphics card not detected
For me, The AMD Radeon card which comes as the second graphics card in this laptop, has completely disappeared in the system. Task manager, Device manager, or dxdiag do not recognize it, and amd driver installer doesn't detect it either, the copy of linux I also have installed on the system, doesn't recognize it either. I haven't opened it and would rather not. What do you think could be the problem?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
Hi @amiratashi
Perhaps check in BIOS to see if there's an option to disable the AMD GPU.
If there's not, there's some reason why the GPU is not communicating with the I/O chipset on the motherboard so you will have to open it up and see if anything obvious is wrong. After that you may need the schematics to find out what's happened.
Here's the hardware maintenance manual that will help gain access to the motherboard
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Thank you for your anwser @jayeff
из
Добавьте свой ответ
Amir Atashi буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 430
