Why battery draining down fast
Battery draining fast
Это хороший вопрос?
Hi @aijazahmed
Try replacing the battery and check if that resolves the problem.
Here's a video that shows what to do.
Search online for B-H0 battery to find battery suppliers that suit you best.
Был ли этот ответ полезен?
First, check if the battery is bloated or not if it is bloated change it with a similar 4500mah battery.
If the battery is not bloated first change the app's background running setting to off from setting and stop other background processing you don't want.
Next, stop all unnecessary notifications and turn on the dark mode it boosts your phone battery life.
If it didn't work try replacing the battery and check if that resolves the problem.
За последние 24 часов: 1
За последние 7 дней: 16
За последние 30 дней: 82
За всё время: 2,729
9 Комментариев
Battery drains fast I am vivo phone
из kishore kishore
@kishorekishore How old is your battery? Is this something new or has it been getting steadily worse? Have you considered @jayeff's advice to replace the battery?
из Jerry Wheeler
Battery drain fast
из Hashir Siddiqui
Battery draining issue
из Gangadharaiah R
Very bad battery
из Saguna Raghav
Показать ещё 4 комментариев
