How do I fix black screen?
Here are the symptoms:
-When you press the power button, the screen flashes white twice, then stays black. Otherwise, everything else starts up normally with the chime and hard drive sounds, etc.
-Shining a flashlight to the screen shows it still works (just no backlight?)
-I've reset the PRAM, no go
-I've replaced the inverter board but that didn't work
-It does work with an external monitor attached
I am currently running an extended Apple hardware test to see if it brings up anything specific.
Could something on the logic board be bad?
Bad CCFLs?
Это хороший вопрос?
Счет 0
1 Комментарий
The hardware test did not find anything. Bummer.
из
Добавить комментарий
1 ответ
Выбранное решение
It's the screen connection to the board, screen or video card
Here is the screen guide, take it apart and check the screen connector, if nothing, try a a screen
iMac Intel 20" EMC 2266 Display Panel Replacement
If not, it's the video card or logicboard(I think this model has a MXM card)
I do not know much about the video card built onto the board or a seprate card, but I know this, if it's a ATI(AMD now) or NVIDIA, it's probably on a separate board, if it's intel, no, on the logicboard itself, you will need to take your iMac apart to know for sure about this
Here is the GPU swap guide
iMac Intel 20" EMC 2133 and 2210 Video Card Replacement
iMac Intel 20" EMC 2266 Display Panel Изображение
Инструкция
Сложность:
Умеренно
iMac Intel 20" EMC 2133 and 2210 Video Card Изображение
Инструкция
Сложность:
Умеренно
1 - 2 hours
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
thank you nick, i really appreciated you, its also solve my problem
из
Добавьте свой ответ
mike буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 27
За всё время: 2,693
