Информация по ремонту Creality Ender 3 Pro — улучшенной версии 3D-принтера Ender 3 производства Creality. Выпущен в сентябре 2018 года. Номер модели: Ender 3 Pro.
Why isnt my 3d printer scrolling button working
Scrolling button from my 3d printer doesen"t work, is there any way I could fix that myself ?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
hi,
when you say it doesn't work;
-it doesn't turn?
-it turns but no scrolling action of the screen?
Был ли этот ответ полезен?
Счет 0
3 Комментариев:
yes, it moves but it isnt shown on the screen
из
Most of these random - out of nowhere issues are commonly caused by firmware corruption. A simple reflash of the firmware usually does the trick. Have you done any modifications? if so, double check your connections.
-Double check the ribbon cable connection from the LCD to the main board.
-inspect for broken, loose , burnt components.
-reflash the firmware.
-When i started having issues with my ender 3(after 2 years of use) I upgraded the board with the SKR mini E3 . Not only did it solved all my issues but the printing quality and performance improved as well.
из
thanks for your help
из
Добавьте свой ответ
guy with 3d printer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 25
За всё время: 534
