Отремонтируйте свой смартфон Samsung Galaxy S10 5G с помощью этих руководств по самостоятельному ремонту и замене деталей.
Blue connection not turning on
When I try to enable my Bluetooth through the status bar or in the settings the nob Icon will not turn on. However my wifi connectivity still works perfectly
Это хороший вопрос?
Счет 1
5 Комментариев
Did this happen after an update?
из
Please see if phone reset helps
из
@oldturkey03 I highly appreciate the feedback, I just tried the Safe mode trick and still had no luck. I now strongly believe that the issue might be hardware related.
из
@markusnorstroem Not necessarily, I used the phone for over a year and a half with the latest update. I believe the issue might be hardware related.
из
@i_am_the_cosmos unfortunately that did not work, I tried a network reset and still had no luck. Thank you for your input
из
Добавить комментарий
2 Ответов
Выбранное решение
@bwalyamataka since your WiFi still works you may have issues on a component level. First you must rule out that this is a software issue.
First start your phone in safe mode. To place it in safe mode, use the Samsung instructions from here Once in Safe mode give it a try and see if it works now. If so, you know that you have a bad 3rd party App on your phone. It will not tell you which one so you will have to delete one after the other until you find the one that causes this issue.
If it does not get better in Safe mode, it is not an App etc. and you can exit safe mode.
Check the Bluetooth firmware version of your phone by dialing ****#2663#*** and see if it shows up properly. ******Anything after that would lead me to having to check the components on the board. Looks like your phone is a SM-G977. There are no free schematics out there but you can can get them through fee-for-service $$
Был ли этот ответ полезен?
Счет 1
@bwalyamataka
Try wiping the cache partition and check if that resolves the problem.
Go to Wipe Cache Partition → Samsung
Счет 1
Добавьте свой ответ
Bwalya Mataka буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 6
За последние 30 дней: 25
За всё время: 435
