Информация по ремонту и обслуживанию ноутбуков Dell Inspiron 15" (дюймов).
No display. White LED blinking.
Earlier this had a bad battery issue. (Some combination of Amber and white.) But it worked after clearing CMOS. But now Fan spinning for about 3 seconds and the white diagnostic led blinking. Tried clearing CMOS, and unplugging everything unnecessary.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@lewishamilton use the 5000 series Inspiron 15 5567 Servicemanual En Usand check page 85 to determine what the trouble code will look like. If it is a continuous white light that blinks, this appears to be a non-specific hardware failure code. I would try this first. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
It would have been nice if you could remember what happened on here (Some combination of Amber and white.)
Был ли этот ответ полезен?
Счет 0
4 Комментариев:
Hi, Yes I checked the service manual before starting the thread, but there isn't anything similar.
Already tried that but no success.
Unfortunately, I can't remember the exact combination. But I checked some Dell manuals and mentioned as bad battery.
из
@lewishamilton that could most certainly be a possibility. Commonly a bad battery should not prevent your computer from coming on. Remove/replace it and also remove the RAM and see if that changes anything. A bad Ram stick can prevent your computer from coming on.
из
@oldturkey03 I don't replace it for TSing - I disconnect it, wipe the CMOS RAM and reconnect. That usually does the job, and the old battery can be reused.
из
@nick not for the troubleshooting. You are right, for that you only need to disconnect the battery.
из
Добавьте свой ответ
Lewis Hamilton буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 20
За последние 30 дней: 80
За все время: 1,457
