Compatible Touchpad Replacement Parts
I am trying to replace the touchpad as it has a constant Error code 10 when trying to connect, through reinstalling the drivers and updating them it doesn't work. Are there compatible touchpads from other laptops that I can use in place of it? I am having trouble finding a replacement touchpad which I believe is the problem.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @kylew87212
Check if there's a part number on the touchpad and search online for the number to find suppliers.
Here's the hardware maintenance manual for the laptop that may help.
Go to p.59-p.60 to view the procedure to remove the upper case with keyboard assembly, so that you can see if there is a part number on the touchpad.
The parts list for the model, doesn't show the touchpad as a separate item as it is most probably included as part of the C-cover with keyboard assembly. Click on Machine Type > Select Commodity to see all the available parts and their part numbers.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
I looked up the part with the stickers on the back it looks like the vendor was CNY the P/N: was PK37B01FL00 P531003290000AEJ
it came up with nothing but I am probably going to look into what you mentioned because it would get me the part but the keyboard would be a waste unless someone brings me a broken keyboard.
из
Добавьте свой ответ
Kyle W буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 324
