Информация по ремонту и диагностике портативной зарядной станции FixHub, основного источника питания и интерфейса управления для линейки продуктов iFixit FixHub. Выпущена в октябре 2024 года.
Factory reset, CLI serial commands
Hi, does anyone know a command to return the FixHub to it's original shipped state?
Am thinking this would be via a terminal session, as the "knob" doesn't seem to show this option.
Also, is there any documentation on the CLI serial commands?
Some, like mcu-sn or toolinfo, are fairly straightforward, but am wondering if there's a comprehensive list of the other commands, similar to a man page.
Это хороший вопрос?
Счет 4
Добавить комментарий
1 ответ
Выбранное решение
Hi @osxtra ,
There is no menu setting on the Power Station to reset factory defaults, nor is there on the web interface (currently).
In the meantime, these are the default settings:
Language (English)
Power-Off Timer (10 min)
Timer Enable (Enable)
Max Charge (100%)
Error Log (clear error log)
We also don't currently have a public spec for the serial terminal commands. We might in the future.
Был ли этот ответ полезен?
Счет 1
5 Комментариев:
Tanks for the info, Kris!
из
I do not see the option "Max Charge" in my menu. Is this part of an update?
из
@omegatotal Yes, you should be able to see this option once the firmware is updated (not sure what exact firmware version number this would be when this option first appeared).
из
Nice 6 month turnaround
из
omegatotal, I see your 6 month turnaround and offer a seven.5 month one in return: ;)
CLI commands and STL files for the hub and irons can be found on iFixit's GitHub site:
https://github.com/iFixit/FixHub
из
Добавьте свой ответ
osxtra буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 20
За всё время: 528
