Screen change for my hp
How do I change my screen
Это хороший вопрос?
Here's the maintenence and service guide for the laptop.
Go to p.70 (80 of 122 pdf) to view the procedure to remove/replace the display assembly.
On p.76 it shows how to remove the LCD panel from the display assembly.
Also on p.76 there are the HP part numbers for all the different LCD panels that can be used in the model.
Search online for the appropriate to your particular model LCD panel part number to find suppliers that suit you best. Usually the HP part number can be found somewhere on the back of the LCD panel itself, if you want to verify that you're ordering the correct one.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 27
За всё время: 483
