27-дюймовый IPS-монитор LG UltraFine 5K с поддержкой macOS
Monitor no longer powers on
The monitor no longer powers on, and does not connect or power my MBP. It sounds like this is a common issue. Has anyone else solved?
Это хороший вопрос?
Счет 0
4 Комментариев:
@harrisehsan does the power LED still come on? What have you checked? What is the exact model number for your monitor?
из
@oldturkey03 No it does not. Nothing happens at all. There is no real sign it is working. But I spoke to a repair shop that said the motherboard has known issues that cause this, so it should be repairable. Model number is 27MD5KA
из
Replace the motherboard then
из
@senopatib I'm hoping someone here can explain how
из
Добавить комментарий
2 Ответов
I couldn't find the exact monitor that you have but from searching maybe this could help:
https://youtu.be/ytKg1dsMv4U?si=pjGamcu9...
Был ли этот ответ полезен?
Счет 0
@harrisehsan don't replace anything yet until you have at least had a chance to take a look at it. Use this guide Разборка LG UltraFine 5K to get to the boards. Then post some well-focused pictures of everything with your Question. That way we can see what you see and hopefully assist you further. Adding images to an existing question - iFixit Repair Guide
I expect this to be an issue with the power supply.
iFixit Изображение
Инструкция
Добавление изображений к существующему вопросу
Сложность:
Очень просто
2 - 5 minutes
LG UltraFine 5K Изображение
Инструкция
Сложность:
Умеренно
Счет 0
Добавьте свой ответ
Harris Ehsan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 19
За всё время: 418
