Not draining even after pump change
I have a Frigidaire dishwasher model LFID2426TF1A about 4 or 5 years old. A week or so ago it stopped draining. Having seen this movie before (different house different dishwasher) I assumed it was the drain pump. I just replaced the drain pump and it is still not draining.
There is no garbage disposal hooked up to it - no disposal at all.
I took the filters out of the basin prior to ordering the pump in case the issue was a clogged filter but after a good clean there was no change.
The drain hose is not clogged.
It makes sounds like it is draining but when it’s done and I open it up the entire basin (tub?) is full. This is true both before and after the pump replacement.
I’m about to order a pump and motor assembly but I don’t like to just throw parts at things when I’m not sure.
Anyone know what I should do? Is the pump assembly the right move? Is there something I’m overlooking?
Thanks
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi @sis6598116
There's a check valve on the outlet of the drain pump. Did you check to see if it was working OK?
Here's a link to the service data sheet that may help.
If you find the problem and a part needs replacing here's the parts list that is useful.
Locate the wanted part in the list and note the manufacturer's part number that is listed with it. Search online for the part number only, to find suppliers that suit you best.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
That was it. I hadn’t given that a thought. Took me until today to be able to check it. Draining like normal!
Thanks so much!
из
Добавьте свой ответ
Sis65 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 12
За последние 30 дней: 81
За всё время: 1,976
