Информация по ремонту и разбору MacBook Air модели A2172 с процессором Intel, вышедшем в марте 2020.
Replaced battery not charging
My macbook air would not stay on unless plugged in and also said service recommended, so I decided to replace the battery. I followed all the steps to do so and was successful. My macbook now turns on, has a charge, and no longer says service recommended, but when plugged in there’s no indication that it’s charging or even connected to a power source. I tried resetting my SMC as advised online, but no luck. Should I now look into replacing my usb-c board, or is there another solution I could try first?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Let’s get a better view of things install this gem of an App CoconutBattery take a snapshot of the apps main window and post it here so we can see things.
Был ли этот ответ полезен?
Счет 0
3 Комментариев:
I added a screenshot to my original post.
из
@huntermarshall - Let’s let it charge for a good 6 hrs and then take a fresh CoconutBattery snapshot. This time let’s do the snapshot with the charger plugged in as we do need to see if the charger is charging.
из
that was taken with the charger plugged in. that’s what makes me think it’s the usb-c board, but in reality i have no idea about any of this.
из
Добавьте свой ответ
Hunter Marshall буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 22
За всё время: 280
