What is wrong with my screen?
There is a big white line on the screen of my camera. It works just the same nothing is wrong with it other than that. I placed it on top of my game console and when I went to use it today, there was a big white line on the screen. What do i need to fix it.
Это хороший вопрос?
4 Комментариев
Hi @gamingwithchris
Is the line showing up in pictures taken by the camera and then they're downloaded and viewed on a TV. monitor etc?
из jayeff
Hi! It’s a line around the middle of the screen. It’s not in the pictures I would say, it’s on the whole screen no matter what mode I put it in. I haven’t tried to download it onto another device but as of right now it goes from the top of the display to the bottom. And when I try to change the brightness of the screen, it doesn’t affect the white line, it stays very bright while the screen does not
из Gaming With Chris
@gamingwithchris
You need to verify and not guess whether it is just seen in the camera screen or if there's also a line seen in pictures taken by the camera, downloaded and viewed on a different screen
If it is in the LCD screen in the camera only then most likely it is the screen that it the problem and it can be replaced.
if it is in pictures also then it may be a motherboard problem, a lens problem or both.
Post an image showing the line in the screen here's how on ifixit Добавление изображений к существующему вопросу
из jayeff
@jayeff I have added the image, and I also verified that is just on the camera screen, I viewed the pictures on my computer and they are perfectly fine.
