Back glass dimensions, or schematic
Hey, I'm trying to 3d print or CNC a replacement back glass panel for my phone, but I can't find any dimensions anywhere
Does anyone have measurements, or should I order a replacement and take them myself
Это хороший вопрос?
Счет 0
3 Комментариев:
Hey, thanks for replying! Unfortunately, I need exact measurements. I was just asking here before I order one to measure myself.
из
@stuartgree53900
I thought that down to a 1/10th of a mm (0.1mm) would be accurate enough.
Even Vernier callipers only go down to 0.1mm.
How do you intend to measure it more accurately? Just curious
из
Doing it myself will probably be fine I just wanted to see if anyone else had done it.
из
Добавить комментарий
2 Ответов
Hi @stuartgree53900
Here's a link showing the phone's overall specifications including the dimensions that may help.
Here's the ifixit Samsung Galaxy S24+ repair guide that may come in handy when you have printed the back glass panel.
Был ли этот ответ полезен?
Счет 0
I found this CAD:
https://www.printables.com/model/748111-...
I recently did a similar thing for iPhones, I got a bamboo iPhone X back and an acryl iPhone 12 mini :-). Laser cutting is probably your best bet as CNC is quite expensive and 3D printing is either fragile (layered) or will lose its accuracy because of hardening (resin).
Счет 0
Добавьте свой ответ
Stuart Greer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 25
За всё время: 357
