LG V60 ThinQ 5G, часто называемый LG V60, — это Android-фаблет, выпускавшийся компанией LG Electronics как часть серии LG V. Он был анонсирован в феврале 2020 года и является преемником LG V50 ThinQ. 5 апреля 2021 года компания LG объявила о закрытии своего подразделения мобильных телефонов и прекращении производства всех оставшихся устройств. В LG отметили, что телефоны будут доступны в продаже до тех пор, пока не закончатся складские запасы.
Right channel audio gone
The right channel audio does not work (bottom loudspeaker, right channel with wired earbuds. bluetooth is fine). I've had this issue for a while, and I decided I would replace the parts that (I thought) were defective. I replaced the bottom loudspeaker, the 3.5mm jack, and the antenna/sound board (I had also done other repairs during this such as replacing the bluetooth antenna, the battery, and the charging flex cable, all of those seem to be working fine now. It should also be noted that my flex cable replacement and the antenna/sound board replacement were ordered separately and did not arrive as one piece.) Even after doing all of that, there is still no audio coming from the right channel. I honestly don't know what to do now.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
I have this problem too.
And after cleaning these two part with contact cleaner and cotton swab, both speaker and headphones works fine again.
However, after the fix, the phone can't connect to PC anymore. and charger with QC doesn't charge with full speed; it only reach full speed with PD charger. I guess I broke something during the clean.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
beaviszep буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 20
За все время: 202
