Игровой ноутбук серии Republic of Gamers, выпущенный в 2015 году. Модель GL551J оснащена видеокартой GeForce GTX 860M и 15,6-дюймовым дисплеем Full HD 1080p.
tab key is not working
keyboard tab key is not working
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Well you try the different keyboard and check if the tab key is work or not of that keyboard as well and also check for the outdated keyboard driver as well some time an outdated driver can be the reason of this kind of issue as well you can check the driver manually or you can check the outdated driver with a good tool which can help you in update the driver as well like Advanced Driver Update or any other good driver updater tool.
Был ли этот ответ полезен?
Счет 0
Well you try the different keyboard and check if the tab key is work or not of that keyboard as well and also check for the outdated keyboard driver as well some time an outdated driver can be the reason of this kind of issue as well you can check the driver manually or you can check the outdated driver with a good tool which can help you in update the driver as well like Advanced Driver update or any other good driver updater tool.
Счет 0
Добавьте свой ответ
German T буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 9
За все время: 194
