Седьмое поколение Honda Accord, выпускавшееся с 2003 по 2007 год.
Had it with this car
When I put the key in and turn it there's power to the radio and dash lights but nothing happens.ivereplaced the battery,starter and the alternator.can somebody help me before I junk car I've only driven once
Это хороший вопрос?
Счет 0
2 Комментариев
@haditwitht10621 you have no power anywhere but the Radio and dashlights? do the head lights turn on? Did you check the main power fuse? What exact year and model is your Accord? What engine size? There should be a 100A fuse (#1)and a 50 amp fuse (#3) in the under the hood fuse panel
из
2003 accord 2.4L I have headlights,dash lights all interior lights just nothing happens when I turn the key
из
Добавить комментарий
1 ответ
Выбранное решение
Hi @haditwitht10621
Here's the wiring diagram from the 2003 Accord service manual showing the starter motor circuit that may help.
You need to check if the starter relay is operating when the ignition key is turned and if not then it may be a faulty ignition switch a faulty start relay, a faulty switch on the clutch pedal (MT) or the gear shift when in Park (AT), a faulty starter motor or faulty relevant fuses or wiring in the circuit.
(click on image)
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Thank you I'll try that
из
Добавьте свой ответ
Had it with this car буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 21
За последние 30 дней: 64
За всё время: 799
