How to clean the header gasket
How do you clean the header gasket
Это хороший вопрос?
What year is the vehicle, what engine size does it have i.e. 2.0L, 3.0L, 4.4L or 4.6L and what is the problem with the engine?
You don't clean head gaskets.
The only time a gasket should be a concern is if it is "blown" i.e. gasket is leaking which causes the engine to malfunction due to possible oil leaks, coolant leaks, loss of compression, engine misfiring etc depending on where it occurred.
If this is the case it needs to be replaced before any more damage occurs to the engine.
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 18
За всё время: 140
