How to replace the keyboard
Now I will show you how to replace the keyboard of a Dell Inspiron laptop.
You have to prepare some equipment including a flathead screwdriver and a new keyboard.
Remember to remove all the peripherals like the AC adapter and battery from the laptop. Don't use a razor blade because it might leave some scratches on your laptop.
There are 8 steps in total:
  • First, slide two battery-release latches into the unlocked position.
  • Next, remove the battery from the battery base.
  • Then, turn over the laptop and open it.
  • After that, use a small flathead screwdriver to pry away 5 keyboard latches.
  • Next, you should carefully lift the keyboard.
  • Then, disconnect the keyboard cable.
  • After that, remove the old keyboard.
  • Finally, reverse the above steps to install the new keyboard.
I have just told you the steps to change the keyboard. If you have any questions, don't hesitate to contact us.
Это хороший вопрос?
Счет 0
1 Комментарий
I need some images and instructions on each image
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @jaygizo
Here's the ifixit Разборка AST Ascentia 520i guide that may help.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Anh Tuan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 21
За все время: 178
