Ремонт и дополнительная информация о холодильнике Frigidaire GRFS2853A* — отдельно стоящей модели 2021 года с автоматической разморозкой, без встроенных функций, таких как диспенсер на дверце или ледогенератор. На этой странице представлена информация для моделей, номера которых соответствуют шаблону GRFS2853A*.
My refrigerator continues beeping
My refrigerator is cooling properly, freezing properly, making ice properly, but the light on the door continuously flashes and it keeps beeping overtime the light comes on. And it is constant. Power cycling it doesn't work. Pulling the power for over an hour doesn't work. Holding the Crush to reset it didn't work. We are about to lose our minds. Any ideas?
Это хороший вопрос?
Счет 0
4 Комментариев
Hi @tonyrogers
What is the full model number of the refrigerator?
What light is flashing?
из
GRFS2853AF0
It is the light in the door water/ice dispenser, under the temperature controls
из
@tonyrogers
Does the water dispenser work OK?
из
Everything works fine. Ice and water. Refrigerator is cooling and freezer is freezing. Just beeps and flashes the light.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @tonyrogers
I don't know.
The only thing that I can suggest is that you use the service data sheet to run the diagnostic tests and check if any errors are shown.
Maybe perform the tests for the door switches, dispenser paddle and lights first if no errors show when first entering diagnostic mode.
Hopefully it is not a control board issue.
If you find the problem and it's a faulty part that needs replacing, here's the parts list that is useful.
Locate the wanted part in the list and note the part number that is shown for it. Search online for the part number only, to find suppliers that suit you best.
If you search on YouTube for (insert wanted part number) replacement, sometimes if you're lucky you'll find videos that show how to replace the part.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Thanks. I will check it out.
из
Добавьте свой ответ
Tony Rogers буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 17
За всё время: 214
