Kenmore — популярный бренд бытовой техники, широко продаваемый в магазинах Sears, однако сама компания Sears не занимается производством этой техники. Вместо этого они привлекают сторонних производителей для изготовления своих приборов. Холодильники Kenmore выпускаются множеством разных производителей, включая LG, Electrolux, GE и Whirlpool.
Door bottom support broken
Refrigerator door is misaligned. Too low, scrapes the bottom of inside of frig as you try to close. Tried a taller leveling screw but bottom of frig door just collapses and door will not get back to original location. Is the bottom of the door that supports the leveling screw replaceable or fixable. Thx
Это хороший вопрос?
Счет 0
2 Комментариев:
Hi @bdwest23242
What is the model number of the refrigerator?
из Поделиться
253.67879509
из Поделиться
Добавить комментарий
1 ответ
Hi @bdwest23242
If the lower door scrapes the inside of the compartment, it may be a loose lower hinge bracket, worn hinge pin or spacer.
Here's a video that shows how to replace the hinge pin that may help.
It shows how to gain access so that you can check if the bracket (bent/loose?), the hinge pin (worn?) and spacer are all OK or not.
If replacements are required, the part numbers are as follows. Search online for the part number only to find suppliers that suit you best.
lower hinge pin = 240516502
spacer = 240311303
lower hinge bracket = 240314011
Note: The refrigerator is a Frigidaire model, made for Kenmore as it is made entirely from Frigidaire parts. That's why parts results show Frigidaire name. Kenmore doesn't make appliances, they rebadge/made to order other makes of appliances e.g. LG, Frigidaire, Whirlpool etc
Connects the refrigerator door to the lower hinge, allowing it to pivot. Изображение
Товар
Electrolux Refrigerator Lower Hinge Pin - 240516502
$53.99
Supports the refrigerator door at the lower hinge point. Изображение
Товар
Electrolux Bracket-Lower Hinge - 240314011
$65.99
Nylon washer for refrigerator hinge, sold individually. Изображение
Товар
240311303 - Frigidaire Refrigerator Hinge Nylon Washer
$18.99
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Unfortunately lower bracket all good. So is pin and spacer. It’s the door itself that has an issue. Caved in and can no longer support the pin. Thx for the reply. I’m assuming I would have to change door. Correct ?
из Поделиться
@bdwest23242
Looks like it will have to be as they're a sealed unit i.e. filled with foam insulation
According to this parts supplier there are 3 doors compatible with the model
Part # 241623407, 240438617 & 240438619 click on Door parts diagram, expand the diagram to see part #15 in the diagram.
из Поделиться
Добавьте свой ответ
Bdwest буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 28
За все время: 219
