Инновационный активатор 4-Way от LG в сочетании с технологией TurboDrum максимально эффективно воздействует на белье, обеспечивая тщательную, но бережную стирку.
Machine stops a 2 times per cycle
Washer stops 2-3 times, all the cycle lights and the warm water flash. If I click the start button twice the machine unlocks and locks and then keeps going. I have already checked the water valves for blockage and used the smart LG diagnostic- nothing is “wrong”.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi @jonthn93783
Go to p.30 in the service manual and run the machine in service mode and check if that shows if anything is wrong.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
The problem has persisted…I have tired to ohm out the water inlet valves (all seem to be fine), the LG app produced an IE error when I conducted the sound test, but verified no kink in water hose or lack of water pressure. The cycle only runs for about 5 minutes…usually after the initial tub is filled with water. Any ideas? I’m not sure a technician can troubleshoot further without replacing random parts?
из Поделиться
@jonthn93783
Just verifying that no errors were shown when running the washing machine in service mode as described in the service manual?
из Поделиться
An unbalanced load will give an error and only happens during the spin cycle if it can't rebalance by filling with water. A faulty door switch or loose connector to it, might be causing this.
Счет 0
Добавьте свой ответ
JonThN буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 24
За все время: 237
