14-дюймовый ноутбук с номером модели M2C62UA#ABA
Speaker Problems on laptop
I’m facing a problem with my speakers. The sound is distorted and not playing clearly. I’ve tried basic troubleshooting but the issue is still there. Can someone guide me on how to fix this or what steps I should follow? Any help would be appreciated!
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Distorted speaker sound usually points to a hardware fault, dirty connectors, or wrong audio settings. Start by testing with headphones to confirm if the issue is with the speakers or the system. Update or reinstall your audio drivers and check the sound enhancements—disable any effects like Surround or Bass Boost. Clean the speaker grills and ensure they aren’t blocked. Try playing audio from different apps to rule out software issues. If distortion persists, the internal speaker may be damaged, so external speakers or a speaker replacement may be needed.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
I can do all of these method but still same issue my periorty is too i don't change my speaker and my issue resolved is any solution any video aur some of helping that i use please please send me.
из
@muhammadmu90633 since you've already tried basic troubleshooting, reinstall the audio driver for your laptop. If that does not accomplish anything, replace the speakers. To work on that, use the HP Notebook 14 Maintennce And Service Guide
Счет 0
7 Комментариев:
It might be tricky to just find the speakers. I have a few of these because I had to erase them (one has the Ethernet port with possible SATA upgrade path and N4150) and the other is the typical soldered N4150 eMMC 64GB ethernet free model, and parts often cost as much as the laptops. Might be cheaper to buy a donor to get them from. I thought about turning them into Chromebooks with ChromeOS Flex being they're too nasty for Windows, but perfect for something like Chrome OS Flex.
из
@nick use the HP part number 813524-001 to find proper replacements. Tons of them around for a decent price
из
Any method i fix my speaker issue not replace please.
из
@muhammadmu90633 you can always check the connectors as well as the cables., but there is not much else you can do if it is the speakers that have failed.
из
@muhammadmu90633
Can you hear clear sound when using headphones connected to the laptop's audio out earphone socket?
из
Показать ещё 2 комментариев
Добавьте свой ответ
Muhammad Mubashir буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 20
За всё время: 255
