Light not working properly
Light under door comes on dim periodically by itself
Это хороший вопрос?
Это хороший вопрос?
Hi @tee51192
It may be that the light timer has been activated. Try cancelling the light timer and check if that resolves the problem.
Scroll down the relevant page from the user manual to find out how to enable and to cancel the light timer
Был ли этот ответ полезен?
Tee, that light is controlled by a relay on the control bd and is a 110V bulb. Two possibilities: 1. the relay is defective. 2. there is grease build up partially shorting the contacts out. Either way, it should be fixed b4 it causes bigger problems.
Obviously, the first thing to try is replacing the bulb, but for it to come on by itself at low intensity doesn't point to a bulb failure - but anything is possible.
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 19
За все время: 207
3 Комментариев
Hi @tee51192
What is the model number of the microwave oven?
из jayeff
LMV1825SW model number
из Tee
Sorry having problems navigating. First time user. 93 years old
из Tee
