How do I reset check engine light?
How do I reset my check engine light?
Это хороший вопрос?
Hi @steve78064
The check engine light will be gone once you find and fix the problem that has caused it to come on.
It is on telling you that there's a problem with the engine that needs your attention.
The easiest way to find out what the problem is, is to get the OBDII port in the vehicle scanned with an appropriate scantool to see what DTC code (Diagnostic Troubleshooting Code) has been stored. The code tells you what the problem is.
If you're in the USA major auto parts retail stores e.g. AutoZone, PepBoys, O'Reilly Auto Parts etc, do this for free apparently.
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 12
За последние 30 дней: 29
За все время: 148
