Известная как "PS2", это игровая консоль шестого поколения, впервые выпущенная Sony в Японии в марте 2000 года. В США она появилась позднее в 2000 году как SCPH-30000. В России PlayStation 2 начала продаваться 7 ноября 2002 года. Для ремонта этого устройства требуются только обычные инструменты, но он может оказаться непростым.
How would I restore a PS2?
Hello, I have a PS2 looks to be in need of a restoration. The fan has some visable dust, what looks to be the TV port has dirt (hopefully not bug legs) around the edge of the inside of it. I have not tested it yet and I am wondering where to go from here. Thank you in advance.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
Hi!
First, before you disassemble it. Clean it from the outside, clean the fan with a small brush (also the AV port) carefully. And take the dust out.
At last you can also try the vacuum cleaner (low) and remove some dust.
After this test the PS2 and see how it goes.
If it's fine, I would just leave it be. If the fan is making a lot of noise after all of that, then you may want to open it up and remove all the dust further.
Please let us know how it goes!
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
Thank you for the quick responce! I will try this and let you know of the outcome.
из
Alright! Thanks! Good luck and you know where to find us :)!
из
🧹 Initial Cleaning
  • Exterior wipe‑down: Use a microfiber cloth with a bit of isopropyl alcohol (70%+) to clean the case.
  • Fan & vents: Compressed air or a soft brush will help remove dust. Hold the fan blades still while blowing air so they don’t spin uncontrollably.
  • Ports (AV/TV, USB, controller): A cotton swab dipped lightly in alcohol can clean dirt around the edges. If you suspect insect debris, carefully remove it with tweezers before swabbing.
Internal Inspection
  • Open the case: If you’re comfortable, remove the screws and lift the shell.
  • Check for corrosion or residue: Look at the motherboard and connectors for signs of rust, liquid damage, or insect nests.
  • Optical drive: Inspect the disc tray and laser lens. A lens cleaning solution or kit can help if it looks cloudy.
Power & Testing
  • Power supply check: Make sure you have the correct PSU and cables.
  • First boot: Test with no disc inserted. Listen for abnormal noises (grinding, clicking).
  • Video output: Connect to a TV and check if the AV port works. If dirty, cleaning may fix poor signal.
⚠️ Safety Notes
  • Always unplug before opening.
  • Ground yourself to avoid static discharge.
  • Take photos as you disassemble so you can reassemble correctly.
Счет 1
Добавьте свой ответ
Cperson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 45
За всё время: 349
