Troubleshooting P5 error code
Have an LG WKHC152HWA stackable washer/dryer about a year and a half old. The dryer would not start and had a P5 error code a few months ago. Shut off breaker for awhile and it seemed to resolve the issue. Same problem again, turning off breaker will not fix it this time. There is a constant clicking noise coming from the right side of the dryer when the breaker is on, whether the dryer power button is on or off. Can't find repair videos for this specific model. Research suggested most common problems are likely control board, thermal fuse, or blown motor. I replaced the larger of the two control boards, the one on the right side - there is one mounted to the top of the dryer frame on both the left and right sides. Did not fix it. I have it completely torn down now, have tested the motor and it seems fine, cannot locate anything that appears to be a thermal fuse.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @vdngyk4rwkgij4v
Sure it's not a Ps error code?
If it is check the power supply cord and connections to the unit and also the power board to make sure that they're all correct and secure.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
BN буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 53
За все время: 268
