Седьмое поколение плеера Apple iPod Touch, выпущенное в мае 2019 года. Данная модель оснащена накопителем объемом до 256 ГБ и процессором A10. Номер модели A2178.
Apple store battery replace
If I bring my iPod touch 7th gen. into Apple, will they install a new battery in it? About how much will they charge me?
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Apple does WUR replacements on these given the battery is soldered.
Follow this to do it yourself: Замена аккумулятора iPod Touch 6-го поколения (НЕ ЗАВЕРШЕНО)
Был ли этот ответ полезен?
Счет 1
Наиболее полезный ответ
The good news is that Apple does not consider your iPod either vintage or obsolete, so they will indeed replace the battery for you.
You can get an estimate for the cost yourself under their support pages here.
iPod Repair and Service - Apple Support
Here's what comes up as of the date of this post.
This is for the US; if you're in another country your cost may vary, but otherwise you're looking at about $80 for the replacement. A local repair shop can undoubtedly do it cheaper if you're open to that.
iFixit doesn't have a guide for do-it-yourself battery replacement; in my experience they tend not to create guides for parts that are soldered in, as the battery for your iPod is. The question of why there isn't a battery guide has come up before; here's a question that addresses that.
SOLVED: Battery removal is never mentioned - iPod Touch 7th Generation - iFixit
You can, however, buy a battery from iFixit should you choose to attempt this on your own.
iPod Touch (6th and 7th Gen) Battery: Replacement Part
There are plenty of YouTube videos available to show you how to do that job; this one is pretty good.
Ipod Touch 7th Gen Battery Replacement in 2023 - YouTube
The only criticism I have of this guide is that they don't take the extra step of replacing the battery adhesive. Although the old adhesives strips might be fine, if it was me I'd scrape them off and use new ones. Other than that, it gives you all the information you need.
Replace a battery compatible with a 6th or 7th generation iPod touch model A1574 or A2178. Part #020-00425. Battery Model #A1641. 3.83 Volts (V). Изображение
Товар
iPod touch (6th and 7th Gen) Battery
$19.99
Счет 1
Добавьте свой ответ
David Swanson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 28
За последние 30 дней: 111
За все время: 1,013
