Модель конца 2011 года, A1278 / процессор i5 с частотой 2,4 ГГц или i7 с частотой 2,8 ГГц.
No output on external display
Hello all, I have a Late 2011 Unibody MacBook Pro with the Intel Core i7 and 16 gigabytes of RAM. I want to connect another display externally so I can have a dual screen setup and/or use it for presentations, but I noticed that the Mini DisplayPort/Thunderbolt port doesn't seem to work correctly.
Things I have tried:
Tried multiple adapters
(two of the same Mini DisplayPort to HDMI adapters, and Mini DisplayPort to HDMI cable)
Tried macOS 10.13 High Sierra (I run the catalina patch along with the OpenCore Legacy EFI loader)
Tried macOS 11 Monterey
Tried macOS 14 Sonoma
Tried just removing the hard drive and have it display the blinking folder with question mark icon
Tried Windows 10
Tried the Display Menu application on all MacOS versions except Monterey (macOS 11)
SMC Reset
PRAM/NVRAM reset
Those two things when re-installing macOS 10.13 High Sierra.
Clean out the mini DisplayPort/Thunderbolt port, and dongles.
Observations:
macOS (all versions) detects and recognises the monitors, as in the screen flickers and recognises the brand and supported modes (within adapter limits)
Same goes to the pre-boot environment
Windows does not see the external display even after manual detection. Sometimes after reboot the integrated graphics in Windows is disabled due to a problem, re-enabling it brings back proper graphics but external monitor output is still not working or being detected.
All the adapters I've bought show the MacBook Air, not the MacBook Pro, although I've seen a review of someone using it on a 2012 Unibody MacBook Pro
A while back I had a different MacBook Pro model, still 2011 but the Early 2011 one, with the Core i5 instead of the Core i7. I was given a mini DisplayPort to VGA adapter and same symptoms, macOS and preboot environment sees it, but no display out. I was told by the person that gave the adapter to me that they use it on their 2015 MacBook Air just fine with no problems.
Is there like a common fault or difference with these Unibody MacBook Pros with how they handle that specific port and why it seems to be temperamental with cheap adapters? I haven't tried the adapters I've had since other than specific Lenovo ThinkPad laptops and MacBook Airs, I haven't had the opportunity to try them.
I want to try one of the more expensive adapters but I don't want to spend money on something that is not guaranteed to work.
Let me know if there's anything I could do.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
What happens when you close the internal displays lid down? Does the external pop on?
Был ли этот ответ полезен?
Счет 0
7 Комментариев:
No. I also tried booting it and immediately closing the lid, and disconnecting the internal display entirely. No effect.
из
@rainegillingham - Not good 😫
The mDP connector or the logic board wiring to the driver logic has a problem. This will need someone with micro soldering skills to either locate the failed components or you'll need a new logic board as the connector is very difficult to remove and very hard to find a replacement.
из
I found another more expensive adapter which seems to work now. Weird how it didn't work with the first cheap dongles and cables I had that worked with a 2015 Retina MacBook Pro and a ThinkPad X260
из
@rainegillingham - Review the adapters supported scan rates and what your system supports. Per EveryMac - 2011 13" MacBookPro
Apple reports that this system also supports "1152 by 720, 1024 by 640, and 800 by 500 pixels at 16:10 aspect ratio; 1024 by 768, 800 by 600, and 640 by 480 pixels at 4:3 aspect ratio; 1024 by 768, 800 by 600, and 640 by 480 pixels at 4:3 aspect ratio stretched; 720 by 480 pixels at 3:2 aspect ratio; 720 by 480 pixels at 3:2 aspect ratio stretched."
I've never encountered an adapter that didn't work on my 2012 15" which is almost the same as your 13" but I guess it's possible.
из
Yeah no, I know it's weird but after buying this Ugreen adapter thing it works now with my monitor with 1080p 75Hz. Weird how the other adapters I've had worked with a 2015 MacBook Pro and Air but not on this 2011.
из
Показать ещё 2 комментариев
Добавьте свой ответ
Raine Gillingham буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 8
За последние 30 дней: 18
За всё время: 237
