Руководство по ремонту Dell Optiplex 790
Why power button blink orange light
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi @abdulhadi96018
Check which diagnostic LED lights 1-4 on the back of the computer are on as they will tell you what the problem is.
Go to p.73→p.75 in the owner manual to see all the combinations and what to do.
Был ли этот ответ полезен?
Счет 2
An orange light typically indicates a power delivery issue or an internal hardware failure preventing the system from starting. Unplug everything (including the power cable) from the computer and press and hold the power button for around 20 seconds until the pc drains of power. Then, plug only the power cable in and see if that fixes it. If it doesn't, then you can try to see if your PSU is the issue. Locate the small button and LED light next to the power cord inlet on the back of the computer. Press the button. If the LED is solid green, your power supply is perfectly fine. If it remains unlit, or it blinks, your PSU is at fault, and you should replace it.
Счет 0
1 Комментарий:
PSU is perfect but still orange light
из
Добавьте свой ответ
Abdulhadi буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 13
За последние 30 дней: 71
За всё время: 440
