Смартфон Samsung Galaxy A23 был выпущен 6 марта 2022 года. Его можно определить по номеру модели SM-A235F.
Phone exposed to rain; screen shows lines and operates abnormally.
My phone exposed to rain, when i woke up in the morning and turn the screen on after few seconds first i saw white lines and it get whitish background and phone operate itself abnormally. what could be the solution of this.?
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi @durgeshsingh
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a guide that may help as it shows how to open the phone so that you can get access to the systemboard etc.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Был ли этот ответ полезен?
Счет 1
Right here's what you need to do
Step 1. Get device
Step 2. Walk out door
Step 3. Get in vehicle
Step 4. Start vehicle
Step 5. Go to local authorised repair shop
Step 6. Explain issue to service representative
Step 7. hand device over and pay
Счет 0
Добавьте свой ответ
Durgesh Singh буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 12
За все время: 52
