Третья ревизия классического беспроводного контроллера Xbox была выпущена в ноябре 2020 года вместе с консолями Xbox Series X и Series S. Этот контроллер обратно совместим с предыдущими консолями Xbox One и ПК.
Potentiometer of joystick replacement problem
Hello,
I replaced the one potentiometer of joystick from a Xbox Series X controller but when trying it I was not able to calibrate it. Changed again and same thing. Does the potentiometer has to have an initial resistance value so I am able to calibrated? Maybe the resistance is very high/low to be able to
Это хороший вопрос?
Счет 0
3 Комментариев
Did you just change the potentiometer only or the whole joystick assembly? Did you try to cslibrate on a PC or an Xbox?
из Поделиться
I changed only the potentiometer 2 times with no success. The the whole joystick worked. I calibrated it on a emulator in PC because I don't have an actual working Xbox Series X
из Поделиться
Okay, glad that replacing the joystick worked. Should be OK now! Calibrating on the PC should do it! Have a nice day :)!
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
Hi!
Whenever the potentiometer won't fix it, it's advised to replace the joystick assembly completely.
You can follow this guide for that: Замена джойстика беспроводного контроллера Xbox Series X/S
After this is done, you can try to calibrate them again.
Please let us know how it goes!
Был ли этот ответ полезен?
Счет 2
4 Комментариев:
Hi,
Thank you very much. I discovered that I was using the same potentiometers I use for PS5 controller and the resistance value is different (PS5 2k3 ohm and Xbox 10k ohm) so that was the issue why I could not calibrate it
из Поделиться
Ah that explains it!! It’s correct that they are different. Glad that you found out :)! Have a great day!
из Поделиться
I replaced all my ps4 controller sticks with hall sensor ones. Never had a problem since.
из Поделиться
Yes that works :)! But this is regarding a Xbox controller. I heard that sometimes it can interfere here with the magnets.
из Поделиться
Добавьте свой ответ
sascha bauló martínez буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 22
За последние 30 дней: 69
За все время: 227
